Featured Ranger 33 Foot in Great Condition
1K Total Thread Views | 8 Replies | Jump to Last Post (Latest Reply by Crua · Posted: )
Crua
Description
Promise is a 1978 Ranger 33 tall rig sloop designed by marine architect Gary Mull. With her fin keel, spade rudder and encapsulated keel, she is fast and easily handled on all points of sail. Her 130% Genoa on a new Profurl and Barient self-tailing winches makes her perfect for a couple or single-handed sailing. Most lines are led aft to the cockpit to line-clutches and Lewmar winches. Her M-16 Universal Diesel drives her easily and using 1/2 GPH at 1800-2000 RPM she is very efficient. With a full galley featuring a Force-10 propane stove, hot & cold pressurized water system plus filtration, she is perfect for extended trips in the Sea of Cortez or farther. There is a custom mattress in the forward V-Berth as well bunks in the main salon. The spacious cockpit with a dodger, bimini and awning plus custom cushions and Magma Grill make the cockpit very comfortable to relax or entertain. “Promise” has been carefully restored during the past 3 years and is turnkey and ready to sail.
Full Specifications
RECENT UPGRADES
THRUHULLS & PLUMBING (2019)
All seacocks and thruhulls replaced by new ones, all bronze.
All hoses and hose clamps – replaced.
HEAD (2019)
Overhauled head and fittings
New faucet/shower
New Jabsco toilet fittings & Y-Valve
Added teak custom towel rack & floor grate
HULL
2022:
New bottom paint with “Hemple” antifoul paint (3 Gal.)
New zincs
2021:
Topsides painted 2 part LP.
ENGINE & MECHANICAL SYSTEMS
2019:
Rebuilt alternator
New starter motor & solenoid
Full service for oil, oil filters, fuel filters, transmission oil change
New wiring for engine gauges panel
Injectors serviced
Cooling system flushed
New hoses
New zincs
Thermostat checked
Repair engine cowling & refinish top step
New insulation between engine & galley
2020:
New aluminum fuel tank!!!
Replace steering cables
Replace starter cables
Barient winches serviced
2021:
New raw water pump
new freshwater pump
DECK FITTINGS
New stainless-steel stanchions + 2 gates
New custom pulpit
New lifelines (3/16″ 1X19 stainless-steel wire) + gates hardware
New tricolor nav. lights
New running lights
Install “Plath” manual windlass & cap
New “Davis” Windex
4 new fenders & covers 8.5X28
STANDING & RUNNING RIGGING (2019)
All inspected in 2022
Custom long link plates & installation
New stem fitting & anchor roller
New headstay
Profurl C320 roller furling & extensions
New jib sheets
New second reef line
New main halyard
2021
Rebuilt mast-step
2022
New “Garhauer” Boom-vang
New “Pheiffer” traveler car
Replaced and re-bedded fore & aft lower chainplates
2022
New bow cleat
2022
Toe rails totally reinstalled and sealed
2022
New Fridge compressor
2022
New water pump
SAILS & CANVAS
Replace jib leech
New full batten Mainsail – Rolly Tasker 2020
Nov. 2019: Bimini, awning, mainsail cover & dodger repaired.
New binnacle cover.
BATTERIES & POWER
08/2019 – New service and starter lead acid batteries
Rebuild battery box
08/2020 – New solar panel structure w/awning rail & 175 watt flexible “Sunpower”
COCKPIT
New companionway drop boards
Custom companionway hatch & screens
SAFETY
New Titan Whale Gusher manual bilge pump
New single diaphragm pump
MOB pole
New jacklines & clip system
New swim ladder
New West Marine Dinghy
GALLEY
New propane system: tank, hoses, regulator, pressure gauge
Force 10 – 2 burners stove
Water filtration system under the sink
GROUND TACKLE
Bruce 33 lbs. + 70′ of 5/16″ proof-coil short link galvanized chain (2019) + 200′ nylon rode.
2nd anchor: Danforth 22 lbs. with 1/4″ galvanized chain.
3rd anchor: Bruce (Lewmar) 22 lbs. with 50′ of 5/16″ galvanized chain.
Windlass: “Plathe” manual windlass installed 2019 with chain pipe.
Electrical Equipment
Shore Power Inlet – 30 Amp/125 VAC
Battery Charger – ProMariner, Pro Sport 20+
Solar Panel – 175 Watt
Electronics
Depthsounder – Hawkeye
Radar – Raymarine (Not Installed)
Plotter – Raymarine
Compass – Ritchie
VHF – Icom M45
Inside Equipment
Electric Bilge Pump – Jabsco Diaphragm
Oven – Force 10, 2 Burners, Propane
Manual Bilge Pump – Titan Whale Gusher
Marine Head – Jabsco
Hot Water – Engine/ 110 VAC
Wind Pack - Anemometer + Screen Display - Raymarime i60 (Not Installed) New 2023
Autopilot - Raymarine EV100 - (Not Installed) New 2023
Outside Equipment
Teak Cockpit – ✓
Outboard Engine Brackets – ✓
Cockpit Cushions – ✓
Cockpit Table – ✓
Swimming Ladder – ✓
Rigging
Steering Wheel – ✓
Spinnaker Pole – ✓
Sails
Mainsail – Rolly Tasker (2020), Excellent Condition
Furling Genoa – 130%, Good Condition
Engine
Make – Universal
Engine Model – M16
Engine Year – 1978
Total Power – 14hp
Engine Hours – 2379
Engine Type – Inboard
Drive Type – Direct Drive
Fuel Type – Diesel
Propeller Type – 2 Blade
Propeller Material – Bronze
Speed & Distance
Cruising Speed – 5.5kn
Max Speed – 6kn
Range – 200nm
Dimensions
Length Overall – 33.25ft
Max Draft – 5ft
Beam – 9.58ft
Length at Waterline – 26.25ft
Miscellaneous
Seating Capacity – 6
Windlass – Manual Windlass
Electrical Circuit – 12V
Tanks
Fresh Water Tank – 1 X 24 Gal (Plastic)
Fuel Tank – 1 X 21 Gal (Aluminum)
Holding Tank – 1 X 10 Gal (Plastic)
Accommodations
Single Berths – 3
Double Berths – 1
Cabins – 1
Heads – 1
Ranger Yachts/Bangor Punta (USA)
33 Foot
$29000
La Paz, BCS, México
