Sold Mercury SeaPro 200 HP 3.4L V6 V6 Outboard Engine
214 Total Thread Views
maternalsport
SEAPRO ADVANTAGES
  • Reduced Fuel Cost: Advanced Range Optimization (ARO) and closed-loop fuel control on the SeaPro outboards precisely adjust the fuel mixture for optimal fuel economy.
  • Maximum Durability: SeaPro outboards feature a heavy-duty gearcase that is validated at three times the lifespan of recreational gearcase and slips easily through the water, decreasing workload on the engine.
  • Compact Flexibility: The SeaPro outboards mount on 26-inch centers, making them ideal for a broad range of multi-engine applications and simple, seamless repower rigging.
  • Light and Mighty: Less weight means more efficiency. The V6 200 HP SeaPro is the lightest engine in its class. A combination of ample torque and less weight makes these outboards ideal for heavier loaded boats.
SPECIFICATIONS
  • Engine type: V6
  • Displacement: 209 CID (3.4 L)
  • Cylinder Configuration: V-6 (64 degree) with Dual Overhead Cam (DOHC) and 24-valves
  • Full throttle RPM: 4600-5400
  • Alternator: 85-amp (1071 W) with Idle Charge
  • Starting: Electric Start with SmartStart Protection
  • Steering: Standard: Hydraulic; Optional: Joystick Piloting for Outboards Power; Optional: Big Tiller
  • Shaft length: 25" (635 mm)
  • Gearcase ratio: 1.85:1
  • Dry weight: Lightest model available: 483 lbs (220 kg)
  • Trim system: Power trim and tilt
New Boat And Outboard Engines
We specialize in exporting brand New Boat And Outboard Engines to our customers in countries all over the world.
The best quality of our products is consistently based on the best technology and brands from all companies providing New Boat And Outboard Engines, and our very best R&D team from Asia to help find the product you want. Currently we offer the best products and brands from well-known brands such as: EVINRUDE, YAMAHA, MERCURI, HONDA MARINE, SUZUKI and other best brands. Please contact us or visit our website or contact us for check our product available.
New
Mercury
200 HP 3.4L V6
$12500
Miami
