2020 Contour Cadet Salt Water Pedal Boat with Canopy
982 Total Thread Views
Status
Not open for further replies.
robind1
***– Transfer of Title will occur @ Purchase!
*** - Includes 4 white USCG Flotation Seats!
The Contour Cadet Pedal Boat is manufactured of high-quality, two-piece, vacuum-formed HDPE thermoplastic, formulated to have long term resistance to Ultra Violet Rays (UV) as well as the adverse effects of weather & some water conditions. The deck and hull are sealed, stapled & glued. Contour is proud to have supplied personal watercraft to its many customers around the world for the past 30 years. Contour’s Pedal Boat will give years of trouble free use.
The Canopy Top is the perfect accessory to block the sun and harmful UV rays when enjoying a beautiful day on the water. It assembles in minutes and will fold down for easy storage and is protected with the removable Zippered Cover. The 2-bow system attaches at the bow and stern and provides strength, while holding its shape in any condition.
The Salt Water Package replaces the standard fasteners and assemblies with STAINLESS STEEL Hardware and Running Gear to provide years of trouble free service IN COASTAL AREAS WHERE BOATS ARE EXPOSED TO SALT WATER.
FYI… MOST LOW COST PEDAL BOATS ARE ONLY TO BE USED IN FRESH WATER, AND WILL CORRODE & CEASE
TO FUNCTION, IF USED IN SALT WATER (UNLESS THEIR INNER PARTS ARE STAINLESS STEEL)
2020 Contour Cadet AQUA Colored (FOR SALT WATER USE) Pedal Boat
  • Purchased New in 2020 from www.DirectBoats.com / Original Owner (Have to sell...husband unstable on the water)
  • Like New / Only used 4 times
  • Factory Installed w/ Stainless Steel Salt Water Kit
  • Factory Installed w/ Waterproof Marine Vinyl/Fabric lined Canopy w/ Zippered Cover
  • Three-Seater Molded Seating
  • Joy-Stick Steering
  • 4 Carrying Handles
  • Storage Bins Behind Seating
  • Sealed Hull and Deck
  • Easy to Drain One-Hole Plug
  • 6 Paddle Blades / More Torque per Revolution
  • Sealed Ball Bearings – for Quiet Smooth Operation
  • Positive Buoyancy
  • Approved for Small Electric Motor (not included)
  • Length – 80”, Width-58”, Weight-95 Pounds
  • Maximum Capacity-550 lbs., Safe Load Capacity-450 lbs.
  • EMAIL or Message Me for Pickup Schedule – CASH ONLY
Contour
Cadet
$999.00
Severna Park
Maryland - MD
Status
