Sailboat in good condition - 1984 ENDEAVOUR 32.7FT. SAILED ONLY IN FRESH WATER. Located in ST. JOSEPH, MICHIGAN.
Water Tanks
• Capacity: l(Est.) 60 Gals.
• Material: Aluminum
• How secured: Framing
• Heads: GROCO manual -
• Showers: shower, drain, sump and pan
Holding Tank
• Capacity: 1 (Est.) 30 Gals.
• Material: Plastic
• Condition: Good
• Y-valve: Yes
Fuel Tanks
• Capacity: (1) (Est.) 30 Gals.
• Filters: (1) RACOR
HULL & DECK
• Steering: EDSON stainless steel wheel, Cable to quadrant
• Anchors: (2)"Fluke type
• Bow roller: Stainless steel
• Pulplts/Stanchlons/Llfellnes: - coated ss
• Dock lines
• Fenders: Large (3)2021 & Medium pneumatic (2) - 2018
• Dodger
• Swim ladder: Stainless steel at transom
• Covers: Main sail.
ELECTRONICS & NAVIGATION
• Compasses: (1) DANFORTH 4"
• Wind Speed: 2014 Ray Marine
• Depth Sounder 2014 Ray Marine
• Wind: WINDEX
• VHF: New 2014 located in cabin, remote located at wheel
• Chart plotter - ray marine with Interface 2014
• Radar: Ray Marine - a75 Gold with charts 2014
• Autopilot: AUTOH ELM -
• I-70 display Interface 2014
• Barometer: mounted above dinette.
ELECTRICAL
• Shore power cable: MARINCO 30 Amp.
• Batteries - 3 solid NEW 2022
• Panel location: At DC Battery charger - new 2022
• panel near nav station
• Circuit protection: Magnetic breakers
• Spreader lights 2018
PLUMBING
• Thru-hull fittings: bronze ball valves
• Manual pump: WHALE foot pump
• Electric pumps JABSCO: Bilge (2018) & Fresh water (2022)
• Water heater: RARITAN 6 Gal.
• Bilge pump - Electric Bilge: float switch new 2022
GALLEY
• Single deep stainless-steel sink
• Refrigerator: Cool-Matic.
• Stove: 2 burner gimbaled propane with oven
SPARS, SAILS & RIGGING
• Type of rig: Sloop
• Material: Aluminum spar and boom
• Where stepped: Keel
• Step condition: Good
• Winches: LEWMAR: (3)
• Mainsail
• Furling jib
• 150 Genoa
• Main sheet traveler
• Vang: ridged
• Roller furling: HARKEN
• Topping lift
AUXILIARY POWER
\• Diesel Make/Model: YANMAR 3GMF
• Cylinders/HP: 3 / 21 Hp.
• Fresh water-cooling system through heat exchanger
• Raw water strainers: GROCO glass and bronze
• Helm Controls: MORSE dual lever
• Engine room Insulation: Foll and foam
• Shafts: l" stainless steel
• Stuffing boxes: Traditional - cutlass bearing. Replaced - 2016
SAFETY &. REQUIRED EQUIPMENT
• Throw-able flotation horseshoe; - LIFESLING
• PFDs: (2)
• Flares: Yes
• Horn: air horn
• Fire extinguishers: (2) ABC - gauges in green
• Smoke detector: None
• Radar reflector: Yes
• Emergency steering: An Cockpit locker
• Manual Bilge Pump: WHALE Gusher
Additional:
Dinghy 10’ Bris with aluminum floor,
Cockpit cushions.
Bosun`s chair.
Steering wheel cover.
Winter Cover with frame.
Jack Stands (7)
Cabin cushions - foam replaced - covers replaced.
Miscellaneous items to numerous to mention.
Water Tanks
Holding Tank
• Material: Plastic
• Condition: Good
• Y-valve: Yes
Fuel Tanks
HULL & DECK
• Dock lines
• Dodger
• Wind: WINDEX
ELECTRICAL
PLUMBING
GALLEY
• Mainsail
• Furling jib
• 150 Genoa
• Vang: ridged
• Topping lift
AUXILIARY POWER
• PFDs: (2)
• Flares: Yes
• Horn: air horn
Additional:
Cockpit cushions.
Bosun`s chair.
Jack Stands (7)
- Endeavor
- Masthead Sloop
- $29,800
- St. Joseph
- Michigan - MI
