New Replacement Michigan Propeller # 031037 Merc Prop # 48-11324A45
  • Thread starter KodyWallice
2K Total Thread Views
⦁ Manufacturer: Michigan Wheel
⦁ Horsepower: 110 - 330 HP
⦁ Years: Thru 1982
⦁ Model: Bravo Two, II-TR, 215E & 215H, TR Sterndrive
⦁ Specs: Thru Hub Exhaust & 19 Tooth Spline
Propeller Specifications:
Part(s): #031037
Brand:Michigan Match
Material: Aluminum
Diameter: 15 - 1/2
Pitch: 19
Blades: 3
Rotation: Standard (Clockwise)
Naval brass spindle
Rubber cushioned hub (Absorbs impact and the stress caused by shifting gears.)
Rubber bushing (Designed to spin free under significant impact, protecting you lower unit)
100 years of propeller making experience
It fits like your old prop.
It performs better than your old prop.
Michigan Wheel has been making props for almost 100 years, longer than some OEMs have been making motors. Thousands of dealers across the country and around the world sell Michigan Wheel props, offering unrivaled inventory of replacement stock, ready for immediate delivery. Every prop is thoroughly inspected to make certain it meets rigid quality standards. This 100 year commitment to quality and performance is the reason more boat owners pick a Michigan Wheel replacement propeller than all other brands combined.
The highest-grade metals are used on Michigan Match propellers - high quality aluminum and tough 15-5 stainless steel alloy. The tighter grain and compact molecular structure of the metal in Michigan Match props make them far less brittle, far less likely to break. It also makes them easily repairable by a qualified repair facility.
Buy Now for only $100.00 S/H!
$100
Atlanta
Georgia - GA
