97 25ft. Boston Whaler Guardian
  • Thread starter CampFireJack
CampFireJack
CampFireJack
BOSTON WHALER GUARDIAN
THE HEAVYWEIGHT CHAMP
The Guardians center-console design and classic unsinkable fiberglass hull are built for heavy loads. Its simple, no-nonsense design lets you focus on the mission. The user-friendly walk-around deck allows adaptive operation, making it the most versatile workhorse on the water.
ANYTHING LESS THAN UNSINKABLE IS UNTHINKABLE.
The claim is watered down by lesser boats that call themselves unsinkable but come up short. Only the legend remains truly unsinkable. Cut a commercial Boston Whaler in half with a chainsaw (we have) and not only does it not sink, you can still drive it. Even fully swamped, under the worst, repeated abuse – intentional groundings, punctures by submerged objects and collisions in dense fog – this boat floats. On actual missions, Boston Whalers have returned their crews safely to shore with a three-foot hole in the bottom, a crushed bow, or even having been sliced completely in half.
UNSINKABLE CONSTRUCTION
Its foam-core Unibond construction gives the Whaler its unsinkability – up to 2 times the flotation required by the U.S. Coast Guard. No other commercial boat has it. Built with two precisely engineered molded hull pieces fitted together and filled with our proprietary foam, Boston Whalers are fused together to create an unsinkable unified hull. Advanced engineering and high-grade materials give the Boston Whaler a service life and warranty measured by the decade instead of by the year.
Bost Whaler
Guardian
$350,000
Ft. Lauderdale
