1997 CrestLiner SportFish 1750 with 2003 Johnson 115hp Fourstroke
  • Thread starter mattmaassen
Status
Not open for further replies.
mattmaassen
1997 CrestLiner SportFish 1750 The boat and trailer are both 1997, but the motor is a 2003 Johnson 115hp Four Stroke with a 4 blade prop and hydro-shield motor protector installed. I am the second owner of this boat, the first owner boat retired from Minnesota to Texas but bought an ocean boat instead and didn’t really use the boat much before I bought it in 2005. The boat has always been garaged and the axle was replaced with a different one so it will fit in a One Car Garage. The Trailer has a custom shock absorber system installed on it to reduce bounce and make towing easier. I replaced the wheels with galvanized wheels 7 years ago, I replaced the hub assemblies with galvanized ones 7 years ago and I replaced the wheel bearings 4 years ago. Lockage rod storage on the driver side and new 6 rod holders passenger side. Also, I replaced the fenders 4 years ago, also I installed a Fulton Fold away coupler 3 years ago so I should fit in most standard depth garages. I replaced the trailer jack 3 years ago and winch system 4 years ago. 6 years ago I replaced the fuse block with a new one and replaced all turn switches on the dash with new ones as well. It has a new anti-rub bow roller installed 2 years ago. I replaced all of the wiring in the trailer last year and it has all led trailer lights and includes a stainless steel spare wheel with a 4 year old spare tire and galvanized spare tire holder. I replaced the tires on it 3 years ago and replaced all of the leaf springs last year as well as both spring brackets. The boat has two fish live wells one aft and one starboard. I replaced the steering wheel and both main consoles 5 years ago, also it has a digital gas gauge. 2 years ago I replaced the entire boat’s pedestal system with all new Swivl-eze 238 system and last year I replaced all of the boat seats with brand new ones. 7 years ago I replace all of the console and bow anti-skid tape with paint on rough surface. I replaced both bilge pump and aerator pumps 9 years ago with Attwood tsunami replaceable cartridge systems, also I replaced the rear hatch with a new larger one 9 years ago. I change the oil and oil filter every year, I change the fuel filter every 3 years, I replace the spark plugs every 3 years, and the lower unit oil every 2 years. The boat comes with 4 seats, transom saver, two new ratchet tie downs, 2014 Basspro shops 3 bank 5amp per bank xps it battery charger, two trolling motor batteries, one starter battery, Minn Kota PD/AP 74 trolling motor with AutoPilot and 3 year old foot pedal and ram mount stabilizer, bimini snap on top with case, 4 blade spare prop, 6 oil filters, 2 fuel filters, 1 spare oil plug, fire extinguisher, Custom Top Gun fabric snap on cover, Original Johnson motor manual, 6 life preservers, 1 throwable bouy, outboar motor cover. It also comes with two fish finders one Lowrance Mark 5x Pro and one Lowrance Mark 5x DSI as well as one receiver lock and one tongue lock.
Crestliner
Sportfish 1750
$11,499
Raymore
Missouri - MO
Status
